Flamingo renderer
Flamingo renderer
文章Siegfried » 2日 5月 2003年, 18:02
文章HapZungLam » 3日 5月 2003年, 00:09
They are all done in Rhino? cool.
Do you have anything post up there Siegfried? we've never seen your work :wink:
文章Siegfried » 3日 5月 2003年, 14:33
I purchased an original Rhino 3.0 + Flamingo 1.1 recently but too busy la, so. :lol: ....I posted 2 works in this fourm before, check this out, some of them are made in Rhino but rendered in Max.
文章choppy » 6日 5月 2003年, 22:06
我剛想學rihno.......唔知系咪import到max完全沒問題呢???
永遠的巨石3D動畫制作團隊
choppy
文章: 795
註冊時間: 28日 2月 2002年, 08:00
文章Siegfried » 7日 5月 2003年, 09:10
There are several ways to import into max, like .stl, .3ds, .iges, dxf etc. If U're sure the model is perfect without any gap, then .iges is quite good due to it's small size but the rendering speed would depend on the setting for accuracy of the surface U import, the other format are in mesh form, again, the greater the setting, the more mesh would be and of course, finer detail. Normally, I'll stick to .3ds, iges and .stl.
For .iges, if the model was not perfect in Rhino, sometimes the 'trim' features of the model in Max would be flipped, some can be fixed but some can't due to the degree of the surface.
文章choppy » 7日 5月 2003年, 11:30
哦~~~~明白了!!!thank you!!!
永遠的巨石3D動畫制作團隊
choppy
文章: 795
Flamingo
文章leelingzone » 12日 5月 2003年, 15:13
Flamingo系咩黎?
leelingzone
文章: 346
註冊時間: 3日 5月 2003年, 15:20
來自: hk
文章Siegfried » 13日 5月 2003年, 09:10
It is a plug-in renderer specailly made for Rhinocero. Though Rhino has POV and default renderer, but ppl always ask for better and more ka ma. It did very well in radiosity and caustic light control, very easy to use, very fast, the rendering process is something like Shade. But the material assignment looks like Solidworks.
問題
文章leelingzone » 13日 5月 2003年, 14:30
咁系咪整背景用
leelingzone
文章: 346
來自: hk
文章Siegfried » 13日 5月 2003年, 14:53
I don't understand what do U mean by <咁系咪整背景用>, Flamingo is used to render a 3D model, no matter a robot, a car or a scene or a mountain.
關於render
文章leelingzone » 13日 5月 2003年, 17:15
點樣render架,可否貼圖示范?
leelingzone
文章: 346
來自: hk
