If i want to learn Lightwave or Softimage...
文章Maya初仔 » 9日 5月 2002年, 12:42
Any good course school suggest to me? :oops:
i'm studying in Maya now!Cos, i saw many company not use in Maya :-? ! So, i want to study one more softwave in the same time to help me!!!
Many ths for yr kindly help!!! :oops:
Maya初仔
文章: 433
註冊時間: 3日 4月 2002年, 08:00
learning 3 software
文章jly625 » 9日 5月 2002年, 16:18
Basically no individial softimage course in HongKong.
And some LW course is only beginner grade.
My suggestion is goto find some book or internet site to understand what's going on of 3D software. After that another 3D software only interface problem. :D
jly625
文章: 55
註冊時間: 21日 2月 2002年, 08:00
文章Truth » 9日 5月 2002年, 20:12
既然你開始學3D 軟件不久,你可以給自己一個限期去接觸各種不同的軟件,但不要試太久,當選擇了之後就全程投入,不要再受其他的軟件去影響(引誘),就好像選擇女朋友一樣,簡定之後就要一心一意。 :)
我個人覺得,其實沒有一定需要選擇最強或最common的軟件,反而覺得應該選擇一個arm feel最適合自己的軟件,也都是好像選擇女朋友一樣 :P
你在這個階段多接觸不同的軟件都是好事,以免將來後悔。
不過如果你轉了Software,就需要改名了 :D
Truth
文章: 47
註冊時間: 31日 12月 2001年, 08:00
來自: H.K.
文章Gunsmith » 9日 5月 2002年, 21:38
I agree to touch different softwares at the beginning. but different softwares have their limiation at some point . No need to stick with only one program finally . Try to use the strongest areas of that software to do what you want .
Gunsmith
文章: 70
文章Maya初仔 » 9日 5月 2002年, 21:46
:oops: Many ths for u all kindly advises!!! i think i will concentrate in Maya...but i also will see a bit Lightwave..... :oops: Many ths!!!
Maya初仔
文章: 433
文章tdk » 9日 5月 2002年, 23:35
if you want to know or didn't understand something in Lightwave, ask here (lightwave section), may be I can help. I've used Lightwave over 5 years, so may be some of my experience can help your journey.
good luck. :D
tdk
文章: 373
註冊時間: 16日 11月 2001年, 08:00
文章HapZungLam » 10日 5月 2002年, 04:25
Same here, i you have anything want to ask about soft, both 3D or XSI. i will try my best to help you out.
文章Maya初仔 » 10日 5月 2002年, 12:07
:oops: Many many thanks for u all!! if i have anything don't understand i will post it here to ask u guys!! Thanks!
In the mean time,cos, i'm new in 3D softwave , so i 'm just hardworking in simple object (likes apple, orange, bottle.......to get to use in Maya!! Also, "hard-reading" :oops: the english Maya manual!!! After finish some scenes i will post here and pls advise me to improve my skill...Thanks always!!!
Maya初仔
文章: 433
文章HapZungLam » 12日 5月 2002年, 05:15
If you are a Maya user, why want to switch it to lightwave or XSI. Maya is a pretty good software.
文章Maya初仔 » 13日 5月 2002年, 02:11
:oops: i'm not switch to others....i just want to learn one or two more softwave!!!! :oops: i knew Maya is good! But in HK u have to use more softwaves to help u to find a jod..... :-?
Maya初仔
文章: 433
