can 3d max export to maya? or maya export to 3d max?????
文章mogelpoo » 4日 7月 2002年, 21:41
does anyone know can i use maya to export files into 3dmax or
how about 3d max can export some kind of format into maya, also how about autocad too?
pls answer these three question~ :roll:
thx~~~~~~~~~~~
:wink:
I found job lu
mogelpoo
文章: 32
註冊時間: 11日 6月 2002年, 02:45
for 3d max to autocad
文章be@rbrick » 4日 7月 2002年, 21:45
you can save as dxf format in order to open in autocad
and there is a converter to convert the file format across different applications
try this link, there is a product information of the converter
http://www.righthemisphere.com/products/dexp/index.htm
hope this help
be@rbrick
文章: 106
註冊時間: 17日 6月 2002年, 21:49
來自: hk
文章mogelpoo » 4日 7月 2002年, 23:48
how to save.
i dun see any other type of format can save
i have tried export
alos, save as.
is there anything i miss to do?
i really need to use convert file to 3dmax or max to maya.
tell me the flow?
I found job lu
mogelpoo
文章: 32
文章rryria » 5日 7月 2002年, 00:13
just using 3d exploration
it's easy to make convertion
i have checked .obj<->.3ds is available
rryria
文章: 504
註冊時間: 1日 10月 2001年, 08:00
文章daBear » 26日 7月 2002年, 18:45
you can export maya file to obj ( I believe Max can import that)
From Max, you can save as 3ds and there is a plugin for maya that can import 3ds files. you can get plugin from www.highend3d.com
may the force be with you .....
daBear
文章: 25
註冊時間: 26日 7月 2002年, 06:27
來自: canada
