matrix
Film / Commercial / TV / Animate / Game Trailer / Short
不論新、舊、傳統 或 CG 電影/ 電視 / 廣告 / 短片,只要你有興趣,,這裡也讓你發表個人意見 !
matrix
文章leelingzone » 7日 6月 2003年, 22:23
我想問matrix1入面有一幕咪開槍既,之後個鏡頭就停
我想問呢種拍攝手法系叫咩名?
leelingzone
文章: 346
註冊時間: 3日 5月 2003年, 15:20
來自: hk
文章h2o » 8日 6月 2003年, 01:38
Bullet-Time Photography 由 Wachowskis & John Gaeta 所創的詞匯
以下解釋節錄於 http://whatisthematrix.warnerbros.com:
Bullet-Time Photography Super slow motion would be relied on heavily in the stylization of the action scenes in "The Matrix," but certain moments in the script called for something special. These scenes required dynamic camera movement around slow-motion events that approached 12,000 frames per second.
The filmmakers first blocked out the action that was going to be rendered and filmed the scene using conventional cameras. Then they scanned the images into a computer and, using a laser-guided tracking system, "mapped out" the movements of the camera that would capture the final scene. A series of sophisticated still cameras was placed along the mapped path, each of which would shoot a single still photo. Then the photos were scanned into the computer, which created a strip of still images, similar to animation cels. The computer generated "in-between" drawings of the images ?much as animators draw frames to move their characters smoothly from one pose to another ?and the completed series of images could be passed before the viewers' eyes as quickly or slowly as the filmmakers wanted without losing clarity. Obviously, this painstaking technique takes time and precision, but it renders moving objects and people in a completely new way.
給大家回顧一下這經典鏡頭吧! :mrgreen:
http://whatisthematrix.warnerbros.com/c ... deos3.html
文章Cyber Oxygen » 8日 6月 2003年, 22:37
http://www.3dkingdom.org/modules.php?op ... =0&thold=0
這個是 Martix 的子彈效果制作教學......
Cyber Oxygen
文章: 745
註冊時間: 30日 4月 2002年, 12:54
文章meme2 » 8日 6月 2003年, 23:51
用Shake 的 idisplace更方便.
上課學的.
:D
meme2
文章: 8
註冊時間: 8日 6月 2003年, 17:19
slow motion
文章leelingzone » 9日 6月 2003年, 20:09
你意思是slow motion .是不是?
leelingzone
文章: 346
來自: hk
文章h2o » 10日 6月 2003年, 00:25
唔.........點講好呢 :roll:
首先 slow motion 同 Bullet-Time Photography 可以分開黎講.
slow motion 應該知道是什麼啦, 不再多講了.
Bullet-Time Photography 系由一排相機(120部)在同一時間拍了一段 sequence, 接著每部相機抽出一格, 再經剪接成為一段新的 sequence.
最基本的就是這樣喇 :mrgreen:
文章keithwmg » 10日 6月 2003年, 02:54
睇the making of 你會好清楚
keithwmg
文章: 99
註冊時間: 24日 5月 2002年, 15:21
文章leelingzone » 10日 6月 2003年, 19:18
what is the making of?
leelingzone
文章: 346
來自: hk
文章h2o » 11日 6月 2003年, 01:53
制作特輯....... 系我對每部戲"偷師"的地方 :D
回到 影 片 討 論
正在瀏覽這個版面的使用者:沒有註冊會員 和 8 位訪客
