renderman問題
各位可在這裡交流有關RenderMan的問題和分享制作經驗
renderman問題
文章slashkit » 2日 7月 2002年, 01:42
i have install renderman in maya, after i render, only got the alfred windows and havn't find the image display, how can i do for it?
slashkit
文章: 3
註冊時間: 2日 7月 2002年, 01:38
文章h2o » 2日 7月 2002年, 03:15
Did u get any error message?
Did u see ur job in Alfred monitor window?
Are u sure u render ur job into "it"?
Or u select a file format in that column, so that rman render ur job in rman's image folder.
文章Gunsmith » 3日 7月 2002年, 00:23
It could be happened if the PRman home path is not set .
Check the setting > system > advanced > environment variable > find the system variable tab > edit the path ,e.g. C:\Program Files\Pixar\prman-10.0\bin;
also , setting> administrative tools > service > check the Pixar License server is started .
when everything is okay . restart window and see if it can work . I hope this can help you .
Gunsmith
文章: 70
註冊時間: 21日 2月 2002年, 08:00
文章slashkit » 3日 7月 2002年, 01:43
hey, h2o and Gunsmith
thanks for your helps! There is my problems:
After i render in mtor, there is a blue error massage'no huntgroup match (local:pixarRender)' and 'spill-over blocked' in the Alfred window after the date, and there is no image display, i have open 'it' also havn't find!
and Gunsmith, which system variable tab do i need to change, i had find 'MAYA_PLUG_IN_PATH, RATDOCTREE, RATTREE,PRMANTREE'.
i have try to change 'MAYA_PLUG_IN_PATH', but then can't find mtor in the plugin manager in maya.
thanks for help because i want to try to use renderman to render!
slashkit
文章: 3
文章Gunsmith » 3日 7月 2002年, 08:56
highlight system variable 'path' and click 'edit' to add the PRman path .
Gunsmith
文章: 70
文章slashkit » 3日 7月 2002年, 22:19
thanks for help, can use renderman to render now!
slashkit
文章: 3
回到 Pixar's RenderMan
