AVI output in Shake
有關 合成 後期處理 及剪接 的技術/心得交流
AVI output in Shake
文章feverheat » 2日 1月 2003年, 18:04
Dear all, would you please tell me how to render the uncompressed avi file from Shake?
I already create the node ' File Out ' & set to AVI out & the format is ' default' , any setup I am wrong? Pls. correct me , thank you so much for your attention.
***When I rendered the file, it cannot be run in Window media player ( platform : Window 2000 ) ****
feverheat
文章: 132
註冊時間: 23日 3月 2002年, 08:00
文章Solution » 3日 1月 2003年, 11:03
There is a "NONE" option inside the Codec part that you can choose~ but I've try using NONE as codec to render the AVI, it cannot be playback inside windows media player~
I think this should be the problem of shake, since shake using the codec library according to Apple Quicktime library standard, so their "NONE" codec maybe still different from microsoft's "NONE" format~
Since shake using Apple Quicktime library standard, so, even you installed DivX codec, u also can't render your AVI as DivX format.....
Solution
文章: 32
註冊時間: 27日 9月 2001年, 08:00
文章feverheat » 15日 1月 2003年, 18:41
So any suggestion?
Render into TGA files and using other software to do the composit and rendering, like, combustion, AE.....?? Thanks:)
feverheat
文章: 132
文章Solution » 16日 1月 2003年, 11:01
um... i think u can still do your comp process at shake, and render your works at image sequence, then use premier or anythings else to combine them as "Pure" avi file~
Solution
文章: 32
回到 ■ Compositing & Editing
