1st Post - Color Matching
有關 合成 後期處理 及剪接 的技術/心得交流
文章Gunsmith » 14日 3月 2002年, 15:03
I have a newbe question . It is hard to match color of computer monitor (CG )to color ouput for video ? Any suggestion or recommended setup ?
Gunsmith
文章: 70
註冊時間: 21日 2月 2002年, 08:00
文章Stormtroopar » 15日 3月 2002年, 15:29
There are a few things you can do.
- you can set your monitor up so the gamma, colors, and color tempurature are very close to TV or whatever output you are outputting to.
- if you can have a dual monitor setup where you can have your computer monitor and a tv or video monitor, then you can adjust your images or animation by looking at it right through the tv.
Outputing to TV will yield different results from your monitor, so if possible, it is best to do a output and look at it on tv or whatever type of media your final output is going to be to check the colors, contrast, brightness, and so forth... This goes the same for film work. Thats why we have dailys and film out everyday to see the work on the final media.
Hope this helps.
Stormtroopar
文章: 27
註冊時間: 16日 11月 2001年, 08:00
來自: Los Angeles
文章Gunsmith » 18日 3月 2002年, 00:50
Thanks for your hints . It is so helpful .
Gunsmith
文章: 70
Cool
文章xam » 5日 4月 2003年, 17:38
Stormtroopar 寫:There are a few things you can do.
Hope this helps.
Hi Storm, r u working in the effects industries? u r good! :)
回到 ■ Compositing & Editing
