Birds paint effect
Birds paint effect
文章eidosyam » 1日 8月 2005年, 02:43
i have just finished my birds model, 我想做雀仔既羽毛??
應該用什麼方法最好??
eidosyam
文章: 43
註冊時間: 4日 12月 2004年, 00:55
文章stantang » 1日 8月 2005年, 04:30
the easier way is to model pieces of plane then texture map them.
there is not the best or the worst way. Any method is good as long as you get what you want in the amount of time you can afford. :D
文章liarliar » 1日 8月 2005年, 11:16
stantang 兄
我反而好奇想問下你系用script 埋o的patch上去
定系用其他咩方法o架?
因為又多
又要按番佢地個方向, 都有o的難度喎好似
愛人難,我肯學,定能愛下去!
liarliar
文章: 71
註冊時間: 7日 10月 2002年, 17:06
來自: 烏托邦
文章stantang » 2日 8月 2005年, 05:28
Believe it or not, I use paint effect to create the planes. Here is the workflow:
1. Paint strokes on the bird body row by row from head to the bottom
2. apply a "non-mash" paint brush, I use pineTextured
3. pick one of the storke and convert it to polygon
4. change the flatness 1 and 2 to 1 in the brush profile and turn on forward facing (something like that, I forgot the actal term)
5. create a locator, connect the translate to the camera point of the polyShape you just converted
6. play with the "force" under the brush attributes, you can increase the gravity, etc...
7. you can keep change the look (width, length, etc) and the other setting under the brush attributes
8. repeat this for second row, so on... or you can set all the strokes to share the same brush, then break it down again to change the size of plane for different row.
It's a little complex, but you will have a lot of control over the look of the planes. The locator is for control the direction the planes will face.
Another I can think of is instead of use pfx, use hair system to create the hair, then assign a pfx brush to it. Then convert the pfx to poly just as the above. This method could be better for animation since the hair system will take care of the dynamics.
Also you can always use the geometryPaint function to paint the planes on the bird directly. Here is a simple tutoial for that: http://wargasm.fortawesome.com/tutorial ... ntTut.html
文章CraZ3D » 2日 8月 2005年, 05:41
geometryPaint 系的確好用 , 由其paint 大量樹 or 草 !!!
CraZ3D
文章: 1068
註冊時間: 12日 8月 2001年, 08:00
來自: Hong KONG
外號: 富X代
文章liarliar » 3日 8月 2005年, 16:07
真系多謝你o的分享。
為左答謝你
我決定今晚即刻試一次做
體驗一下個過程。
^_^
愛人難,我肯學,定能愛下去!
liarliar
文章: 71
來自: 烏托邦
文章eidosyam » 3日 8月 2005年, 22:21
thank you for idea~~~
i am doing it~~~
i hope i will finished it~~~
eidosyam
文章: 43
正在瀏覽這個版面的使用者:沒有註冊會員 和 11 位訪客
