關於 mapping 既問題
關於 mapping 既問題
文章Media_Tyro » 4日 7月 2006年, 16:46
我系一個完全唔識mapping既人...又唔識打燈........
想問下大家有冇d 基本既mapping可以賜教一下?
我一路都系用blinn 轉下color 就map落去...好差勁............
點先可以做到好有 texture 呢?
thx all!!!
Media_Tyro
文章: 11
註冊時間: 14日 12月 2005年, 17:41
文章darkElf » 5日 7月 2006年, 18:49
You could use texture map to enhance the quality. The advantage is you could put some specific details on the object. eg, scratch, dirt, text ...etc
The first thing u need to do is apply texture project and layout the UV for your 3d object. Then, export the UV layout from Maya and paint texture in Photoshop based on that UV layout.
darkElf
文章: 64
註冊時間: 27日 9月 2004年, 07:40
來自: UK
文章Media_Tyro » 6日 7月 2006年, 01:57
oh thx! darkElf!!
but 我唔識 攤UV.......
Media_Tyro
文章: 11
文章darkElf » 6日 7月 2006年, 10:25
In Maya, Modelling>Polygon UVs
There are 3 basic texture projection you can use - Planner, Cylidrical, Spherical Projection.
Choose a most suitable projection type to fit your object and apply the projection. Then, open Texture Editor to fix some of the overlapping UVs.
A tutorial for your reference,
http://www.etc.cmu.edu/bvw/fall04/uv%20tutorial/UV_Mapping_Tutorial.htm
darkElf
文章: 64
來自: UK
