Cannot Go back to Bind Pose
文章siub » 10日 8月 2008年, 10:42
I built a skeleton and some rig control according to a tutorial. When I move the the rig controls a bit, and then want to restore to the bind pose, the following error will be show: "Error: Pose not achieved. See diagnostics in Script Editor."
When I check the script editor, it shows the following logs. I tried to follow it but I cannot find the "DisableNodes Menu".
select -r Hips ;
gotoBindPose;
// Warning: Could not reach pose on LeftUpLeg rotate. //
// Warning: Could not reach pose on LeftLeg rotate. //
// Warning: Could not reach pose on LeftFoot rotate. //
// Warning: Could not reach pose on LeftToeBase rotate. //
// To disable IK, constraints, and expressions, you can use the Modify->DisableNodes menu.
Other connections can be broken using the script editor.
// Or, to reset the saved pose on a joint, select the joint and enter 'dagPose -reset -name bindPose1'.
// Error: Pose not achieved. See diagnostics in Script Editor. //
BTW, I have no problem when I move the arm's IKhandle and then restore to the bind pose. I have attached the skeleton and see any brother can help. Thanks.
bone.rar
(189.54 KiB) 被下載 508 次
siub
文章: 40
註冊時間: 15日 10月 2007年, 12:14
文章bbkill » 10日 8月 2008年, 13:00
Modify> Evaluate Nodes> Ignore All
Then select you skeleton and Go To Bind Pose
Tested and works.
bbkill
文章: 244
註冊時間: 4日 2月 2005年, 00:45
文章siub » 10日 8月 2008年, 13:34
Thanks a lot.
I tried and the skeleton can go back to bind pose, but the rig controls did not go back to bind pose with the skeleton. Maybe i have done something wrong with the rig controls......
siub
文章: 40
文章bbkill » 10日 8月 2008年, 17:20
You can delete your old bind pose, then create a new bind pose after all rig setup completed.
bbkill
文章: 244
文章siub » 11日 8月 2008年, 10:01
Excuse me.... what do you mean by delete the old bind pose and then create a new one after the rig setup? I don't really understand how to do that. Thanks.
siub
文章: 40
reset/recreate bindPose
文章stantang » 11日 8月 2008年, 10:15
1. Select all joints
2. type "delete bindPose1" in script editor
3. type "dagPose -reset -name bindPose1" in script editor
文章siub » 12日 8月 2008年, 02:21
Thanks. I will try on that.
siub
文章: 40
文章siub » 12日 8月 2008年, 23:51
I've tried but I've got the following error. Did I do something wrong?
delete bindPose1;
dagPose -reset -name bindPose1;
// Error: Found 0 matches for 'bindPose1'. //
siub
文章: 40
