咁.... 我建議你先睇 AE manual 既 interface, import, composition setup
最後就系 rendering 即系 output
kingnt66 寫:There is a check box called "import image sequence", you just need to check the box, select the first image and it will import as image sequence.
I really suggest you to try harder to resolve the problem by reading the manual before you ask for help. The question you asked previously is quite simple and you should able to figure it out by yourself. I understand reading the help files can be tedious, but this is a very good way to learn.
h2o 寫:你可以將裝住 abc.1.iff - abc.100.iff 既 folder, 成個 drag 入去 AE 度
render quality 系取決於咩 format, 無 compress 既 avi 系 keep 到 quality, 但 playback 可能會慢, 視覺上要冇咩分別可以用 quicktime animation or mp4
PetorialC 寫:AVI 其實都有壓縮同唔壓縮(視乎codec)
如果唔壓縮條片可能好大
mpeg那啲(包括mp4)都有壓縮,如果唔系壓得太多條片都唔會失真太勁,但系用得mpeg就一定用少好多位
Quicktime系Apple嘅格式,一定要用Quicktime player或者support *.mov嘅media player先播得
正在瀏覽這個版面的使用者:沒有註冊會員 和 11 位訪客
