Help plz, problem of Paint weight >_<
文章clifford » 25日 7月 2008年, 23:07
相信大家都有試過自己Rigging character, 但系唔知
大家有無遇過當paint weight既時候,油多左,油錯左等等
一禁undo,就有bug. D weight唔知走左去邊,有時d vertexs
唔知走錯哂位...
所以想問,有無人遇過,而且又有辨法解決到?
clifford
文章: 92
註冊時間: 29日 10月 2007年, 00:39
來自: Hong Kong Art School
文章stantang » 26日 7月 2008年, 00:03
What version of Maya do you use? Polygon, sub-d or Nurbs? I remember the older version has similar problems with undo when painting weight but the bug should be gone. Undo works fine in 2008.
文章clifford » 26日 7月 2008年, 15:12
o...或者系因為我用8.0
我只character系polygon黎。
clifford
文章: 92
文章LoGao » 27日 7月 2008年, 12:55
maya 唔知會唔會都有哩個情況,
我系用max o既.
我o系max paint weight o既時候盡可能唔undo 同埋唔paint 負數.
因為paint 負數而vertexs釋放出o黎o既weight,
會由software 以"靠估"o既形式放落其他骨上面,
即系可能o系只手度釋放o的weight 落去個頭度........
而undo有時都唔系"還原",而系好似paint 負數咁.
哩o的錯誤有時會發生,所以我習慣永遠用加數paint weight,
油多o左,油錯o左,
就o系另一節骨度加番o的weight.
o}-<
LoGao
文章: 523
註冊時間: 5日 5月 2004年, 01:51
文章stantang » 27日 7月 2008年, 22:19
In maya, you can't set negative weight value. If you assign negative value of a joint to a vertex, the weight will be distribute to other joints.
It's kind of a "no no" thing to use undo when paint weights, it was buggy but seems like Autodesk fix it after they bought Maya. It still has problem when painting sub-d though, the display won't refresh for some reason.
文章clifford » 2日 8月 2008年, 15:58
O.O原來系咁...
我用過light wave黎做paint weight, 就完全無e個問題
不過又到做其他野果陣有問題-.-"個個software 都唔系完美..."
clifford
文章: 92
