將你個Model cut 間geometry一半(UV ok 個半補留),
1, then Mirror Geometry,choose mirror direction.
eg. +x,-x,+y,-y.......... or
2, Select the half geometry, duplicate with scale -1 with one direction, select both, combine, then final Merge Verticles, Merge Multiples or use Merge Edge Tool.
Good luck
你可以Select你個geometry中間一半個D edges,
then Cut UVs,
In one of your view, e.g. perspective.
Select some UV. one of the half face.
Go to UV texture editor. Select Shell,
then you can move the UVs. Scale your UVs,
what ever you like.
Good luck.
