how to crack maya 5.0.............:-(
文章lk_chin » 2日 5月 2003年, 20:58
i dont have ethernet card i has used maya4.5 before ,i can crack it but afther i uninstall the maya4.5 and i install maya5.0 i cannot crack it again ......can any pls help me ??? :cry: :cry: :cry:
努力!!!
lk_chin
文章: 72
註冊時間: 18日 4月 2003年, 11:27
來自: malaysia
文章HapZungLam » 2日 5月 2003年, 22:14
Maya5 is ez. hum... which crack did you get.
文章lk_chin » 2日 5月 2003年, 22:31
em...i have awkeygen with aw.dat and maya keygen......i dont have ethernet card so i use 000000000000 ..................how to crack it ?
before thaw when i using maya4.5 it can be cracked ...but now i changed to maya 5.0 it become not easy to crack .....can you all pls help me ?? i searching the crack about 4 days ....but still cannot cracked it ......i so tired ....hope you all can help me .. :cry:
努力!!!
lk_chin
文章: 72
來自: malaysia
文章HapZungLam » 2日 5月 2003年, 23:08
put your .dat file into c:\FlexLM
if you don't have the directry, create new.
(mine is a "crick e crock" awkeygen.exe. After i install maya5. run the .exe to create .dat file. Put the dat file onto the location that i mention above. done)
文章lk_chin » 3日 5月 2003年, 14:15
em....still cannot .....because i have liscence the file before in 4.5 ...but i deleted all the flexlm then recreate it....but still cannot ...can anyone pls help me ? :-|
努力!!!
lk_chin
文章: 72
來自: malaysia
文章HONG KONGer » 3日 5月 2003年, 16:04
U might need the MAC address of your modem(if you have one, instead of Ethernet Card). Once U can use Maya 5, U can use 4.5 on same machine.
HONG KONGer
文章: 752
註冊時間: 7日 8月 2002年, 21:14
來自: CHINA
文章HONG KONGer » 3日 5月 2003年, 17:06
Or try 000000000000 as Mac address.
HONG KONGer
文章: 752
來自: CHINA
文章lk_chin » 3日 5月 2003年, 18:13
but still cannot
努力!!!
lk_chin
文章: 72
來自: malaysia
文章lk_chin » 3日 5月 2003年, 18:20
i open the aw.dat fiel it will be like this
FEATURE MayaUnltd sgiawd 5.000 permanent uncounted E06B7FAB7D1D \
HOSTID=000000000000
努力!!!
lk_chin
文章: 72
來自: malaysia
文章lk_chin » 3日 5月 2003年, 18:23
permanent uncounted is what?
努力!!!
lk_chin
文章: 72
來自: malaysia
文章lk_chin » 3日 5月 2003年, 18:35
got somethings i found
i donno what they means
License file: C:\FLEXlm\aw.dat
"MayaUnltd" v5.0, vendor: sgiawd
uncounted nodelocked license no expiration date
This license cannot be checked out because:
Invalid license file syntax
Feature: MayaUnltd
License path: C:\FLEXlm\aw.dat
FLEXlm error: -2,134
For further information, refer to the FLEXlm End User Manual,
available at "www.globetrotter.com".
Hostid required for uncounted feature
"MayaMRFMf" v5.0, vendor: sgiawd
uncounted nodelocked license, locked to ethernet address "000000000000" no expiration date
努力!!!
lk_chin
文章: 72
來自: malaysia
文章HONG KONGer » 3日 5月 2003年, 20:15
1: Install Maya Software.
2: Run LMTools found at Start>Aliaswavefront>Common Utilities>FlexLM License Utilities.exe
3: Click on the System Settings Tab and copy the ethernet address listed in the ethernet address box (That's the MAC address of your network card).
4: Open the aw.dat with notepad and place your ethernet address after ALL of the "=" signs in ALL lines.
5: Save the file as aw.dat and drag it onto the awkeygen.exe (a dos prompt should appear then disappear.)
6: Create a folder in your root drive (c:) called FlexLM and place the aw.dat in there.
HONG KONGer
文章: 752
來自: CHINA
文章lk_chin » 3日 5月 2003年, 22:01
yup it will be like this
HOSTID=000000000000
but i still cant crack it ......
努力!!!
lk_chin
文章: 72
來自: malaysia
文章HONG KONGer » 4日 5月 2003年, 01:06
What's the Ethernet address showed in FlexLM License Utilities?
HONG KONGer
文章: 752
來自: CHINA
文章HapZungLam » 4日 5月 2003年, 05:30
i haven't install 4.5 previously. I just install maya5 as usual. i don't even touch the license, just apply the crack and thats it.
正在瀏覽這個版面的使用者:沒有註冊會員 和 11 位訪客
