/* This file downloaded from Highend3d.com
'' Highend3d.com File Information:
'' Script Name: kwPloySmooth v1.0
'' Author: Kurt Wong
'' Last Updated: July 9, 2004
'' Update/Change this file at:
'' http://www.highend3d.com/maya/mel/?section=polygon#3023
'' Please do not alter any information above this line
'' it is generated dynamically by Highend3d.com and will
'' be changed automatically on any updates.
//SCRIPT: kwPloySmooth.mel
//VERSION: 1.o
//AUTHOR: Kurt Wong
// OnFootBuG@hotmail.com
//DATE: July 9, 2oo4
//DESCRIPTION: This handy Script plays as softImage|xsi does,When you press "+",
// the subdivision levels of the object you select is increased,
// and press "-" to decrease it.
// This Script remaps "Ctrl +" & "Ctrl =" to command "IncreaseManipulorSize"
// and "Ctrl -" to "DecreaseManipulorSize";
//USAGE: 1.Put this script into maya's scripts folder,for example:
// C:\Documents and Settings\yourUserName\My Documents\maya\scripts
// 2.In the maya's command line,type following commands:
// source kwPloySmooth;kwPloySmoothSetUp;
// 3.OK,then everytime you need to increase or decrease the objects'
// subdivision levels,just press "+" or "-" of your keyboard.
// Enjoy it!
//The following procedure finds out all the "polySmoothFace" nodes.
proc string[] kwSeekPsfNodes(string $object)
string $psfNodes[] = {}, $shapeNodes[] = {};
int $psfNodeSum = 0;
$shapeNodes = `listRelatives -s -pa $object`;
string $sources[];
for ($shapeNode in $shapeNodes)
string $temp[];
$temp = `listConnections -d 0 $shapeNode`;
$sources = stringArrayCatenate($sources,$temp);
string $newSources[] = {}, $tempSources[] = {}, $allSources[] = {};
while (size($sources) != 0)
int $sourceSum = size($sources);
$newSources = {};
for ($i = 0; $i < $sourceSum; $i ++)
int $cycle = 0;
for ($allSource in $allSources)
if ($sources[$i] == $allSource)
$cycle ++;
break;
if ($cycle == 0)
if (`nodeType $sources[$i]` == "polySmoothFace")
$psfNodeSum ++;
$psfNodes[$psfNodeSum - 1] = $sources[$i];
$tempSources = `listConnections -d 0 $sources[$i]`;
$newSources = stringArrayCatenate($newSources,$tempSources);
$allSources = stringArrayCatenate($allSources,$sources);
$sources = $newSources;
return $psfNodes;
//The following procedure increases subdivision levels.
global proc kwIncreaseSmooth()
string $sel[] = `ls -sl`;
if (size($sel) == 0)
error ("------->>> No objects were selected, please select any polygon objects you want to smooth. <<<-------\n");
else
for ($object in $sel)
//checking the selected object
string $objType[] = `ls -dag -s -ni -showType $object`;
if ($objType[1] != "mesh")
warning ("------->>> " + $object + " is not a polygon object. <<<-------\n");
continue;
string $psfNodes[] = kwSeekPsfNodes($object);for ($psfNode in $psfNodes) print $psfNode;
int $psfNodeSum = size($psfNodes);
int $dv, $divisionSum = 0;
string $oldName[], $newName;
if ($psfNodeSum == 0)
$newName = "polySmoothFace1" + "_" + $object;
$dv = 1;
$oldName = `polySmooth -mth 0 -dv $dv -c 1 -kb 1 -ksb 1 -khe 0 -kt 1 -kmb 1 -suv 1 -sl 1 -dpe 1 -ps 0.1 -ro 1 -ch 1 $shapeNodes[0]`;
rename $oldName[0] $newName;
else
int $divisions, $dv4Num = 0, $sn = 1;
for ($i = 0; $i < $psfNodeSum; $i ++)
$divisions = `getAttr ($psfNodes[$i] + ".dv")`;
if ($divisions == 4)
string $dvs4obj[];
$dvs4obj[$dv4Num] = $psfNodes[$i];
$oldName[0] = $psfNodes[$i];
$newName = "polySmoothFace" + $sn + "_" + $object;
$sn ++;
$dv4Num ++;
else
setAttr ($psfNodes[$i] + ".divisions") 0;
delete $psfNodes[$i];
$divisionSum += $divisions;
int $dvsLeft = $divisionSum%4, $dvs4Left = ($divisionSum - $dvsLeft)/4 - $dv4Num;
for ($i = 0; $i < $dvs4Left; $i ++)
$dv = 4;
$sn ++;
$dv = $dvsLeft + 1;
print ("------->>> + " + $object + ".divisions: " + ($divisionSum + 1)+ " <<<-------\n");
select -r $sel;
//The following procedure decreases subdivision levels.
global proc kwDecreaseSmooth()
else
//checking object type
continue;
warning ("------->>> " + $object + " is currently not smoothed. <<<-------\n");
else
string $dvs4obj[];
$sn ++;
$dv4Num ++;
else
$dv = 4;
$sn ++;
if ($dvsLeft == 0 && $sn >1)
setAttr ("polySmoothFace" + ($sn - 1) + "_" + $object + ".divisions") 3;
else if ($dvsLeft > 1)
$dv = $dvsLeft - 1;
if ($divisionSum > 0) print ("------->>> - " + $object + ".divisions: " + ($divisionSum - 1)+ " <<<-------\n");
select -r $sel;
//The following procedure maps the hotKeys.
global proc kwPloySmoothSetUp()
hotkey -pcr 1 -k "+" -ctl -name `hotkey -query -name "+"`;
hotkey -pcr 1 -k "=" -ctl -name `hotkey -query -name "="`;
hotkey -pcr 1 -k "-" -ctl -name `hotkey -query -name Dash`;
//Remapping the default hotkeys of commands --- IncreaseManipulorSize, DecreaseManipulorSize;
//mapping "+" & "=" to command kwIncreaseSmooth; and "-" to command kwDecreaseSmooth;
nameCommand
-annotation "kwPloySmooth proc kwIncreaseSmooth"
-command "source kwPloySmooth;kwIncreaseSmooth"
kwIncreaseSmooth;
nameCommand
-annotation "kwPloySmooth proc kwDecreaseSmooth"
-command "source kwPloySmooth;kwDecreaseSmooth"
kwDecreaseSmooth;
hotkey -pcr 1 -k "=" -name "kwIncreaseSmooth";
hotkey -pcr 1 -k "+" -name "kwIncreaseSmooth";
hotkey -pcr 1 -k "-" -name "kwDecreaseSmooth";
savePrefs -hotkeys;
//the end of this script
