請問
請問
文章ADVENTURER » 5日 12月 2005年, 12:19
如何沿著曲線復制物件 ? exp. 整珠仔手鏈
還有 Cluster 是什麼 , 可以用來做珠仔手鏈嗎 ?
ADVENTURER
文章: 270
註冊時間: 6日 11月 2004年, 18:35
文章stantang » 6日 12月 2005年, 05:46
highend3d has two mels doesn exactly that, check here:
http://www.highend3d.com/maya/downloads ... /3775.html
http://www.highend3d.com/maya/downloads ... /2039.html
The simplest way is to apply the a curve as the motion path for an object, then create Animation Snapshots for the that object.
As for the Cluster, you can't create 珠仔手鏈 with that, but you can use it to animate the 手鏈. You should read the the manual for more info on Cluster.
文章ADVENTURER » 6日 12月 2005年, 16:40
thankyou very very much stantang
its so useful and easy to use
it looks like mel are a very helpful tool of 3d
ADVENTURER
文章: 270
正在瀏覽這個版面的使用者:沒有註冊會員 和 19 位訪客
