what is the meaning of these words
文章online_mad2 » 19日 5月 2006年, 19:14
My maya display the following words
"Shadow mapping extensions insufficient to support hardware rendering."
how can I deal with this problem?
online_mad2
文章: 76
註冊時間: 9日 4月 2006年, 22:21
文章h2o » 20日 5月 2006年, 00:24
唔.... 你形容下個 scene 有d咩野, 你想用 hardware ren 做咩?
最好 screen cap d圖黎睇下
文章stantang » 20日 5月 2006年, 10:04
It has to do with your graphic card. Basically, it's saying your graphic card isn't powerful enough to render the shadow map. Just render your scene with software render and render the parts need to be hardware rendered seperately.
文章wwhooo » 20日 5月 2006年, 10:38
Mapping extensions insufficient = wrong file format
Maybe you can try to change your shadow mapping texture file format.
wwhooo
文章: 4
註冊時間: 26日 11月 2003年, 02:14
來自: H.K.
文章stantang » 20日 5月 2006年, 11:08
wwhooo 寫:"Shadow mapping extensions insufficient to support hardware rendering."
The "extensions" here has nothing to do with "file name extension". Shadow mapping extension is one of the "modules" in hardware rendering. You can't use it if your graphic doesn't support it.
正在瀏覽這個版面的使用者:沒有註冊會員 和 21 位訪客
