為何我看不到Curve線????
文章winnie » 17日 12月 2001年, 21:18
我import Adobe Illustrator File to Maya,
我確定the eps file is OK ,And I can see all these Curves in outliner .But Why i cant see all the objects in all of the View ????
What is wrong in My prefernce Setting ??/
Thanks
Winnie :smile:
winnie
文章: 4
註冊時間: 17日 12月 2001年, 08:00
來自: Taiwan
文章mayaBug » 18日 12月 2001年, 01:35
MAYA 有Bug ...
Importing Adobe Illustrator 9.0 eps files into Maya(小弟用4.0.1)會在view睇唔倒~~
試下以下解決方法:
用Adobe Illustrator 9.0 ---> save as an EPS file 及 specify that it be in Adobe Illustrator 8.0 format..
再Import試試....^_^
<font size=-1>[ 這篇文章被編輯過: mayaBug 在 2001-12-18 01:37 ]</font>
mayaBug
文章: 135
註冊時間: 2日 8月 2001年, 08:00
文章winnie » 18日 12月 2001年, 09:10
Thanks.
But I tryied it Before .
I knowed that imported the eps file form Adobe Illustrator 9 cant see anything in the outliner .So I imported the eps from Adobe
Illustrator 8 . I can see all the curves in outliner but cant view anything . I did the same thing in other machine it is fine .
I guest I have something wrong in Prefrence
Setting .
thanks
Winnie :smile:
winnie
文章: 4
來自: Taiwan
文章stantang » 24日 12月 2001年, 05:13
Try to select everything in Outliner, press F to focus to the selection. If you still can see it, zoom in and out and see if the curves are too big. Rescale them if you need to.
正在瀏覽這個版面的使用者:沒有註冊會員 和 12 位訪客
