有咩方法可以令個埸景無咁重?
有咩方法可以令個埸景無咁重?
文章philipcheng » 20日 4月 2008年, 18:37
我個場景有over 50k poly,我用了render layer 先可以render到,而且個場景入面d characters 都set 了animation,但系在home render 會render 到無一半,會stop 左,唔知是不是關場景太重呢?
現在還在學校render 中,希望能成功render 完成render 個二三個shot :(
philipcheng
文章: 331
註冊時間: 7日 4月 2007年, 13:38
文章stantang » 20日 4月 2008年, 19:27
I don't think I fully understand your problem. To be honest, 50k is not that many polygons.... How did you setup your render layers? Do you have each character on its own layer, then have the set as another layer? If so, which layer do you have problem rendering? Set layer or character layer? Are you using MR or SW render? Is there an error when the render stopped?
What version of Maya are you using? It it's 2008, have you update it to SP1 or Ext. 2? I would suggest you do that if you haven't. Another solution is to use 64bit machine to render since it could be a memory problem. Your problem could also be the config of your P, may be it's too old.
文章h2o » 20日 4月 2008年, 19:44
講真我以前做 film 成百萬 polygon 都 render 到, 你有冇用我之前教你既方法 check 左第一步先?
