h2o 寫:用 batch render, quit 左 maya 可以用多d ram 黎 render, 咁又可以 render 重d 既 scene
stantang 寫:Did you check the RAM usage when you render? may be the machine ran of RAM when render. That's I use 64bit, much more stable when render heavy file even with the same 4gb RAM.
stantang 寫:What kind of motherboard do you have? have you update the bios and windows?
It sounds like a RAM problem too. you might want to run some RAM test.
正在瀏覽這個版面的使用者:沒有註冊會員 和 14 位訪客
