To simplify complex CAD data
有關 Modeling 技巧討論
文章cottonsan072 » 13日 8月 2008年, 12:51
If I'm supplied with an OEM automobile CAD model (extremely extremely heavy data) to do high-res still image rendering for print (16K resolution across), is there any particular software available to convert the model from nurb to polygon and simplify it so the model won't choke the machine?
Creativity is the power to connect the seemingly unconnected
cottonsan072
文章: 103
註冊時間: 26日 10月 2006年, 11:38
來自: NEW YORK, USA
文章h2o » 13日 8月 2008年, 13:00
Most HK companies using "Human" converter
文章stantang » 13日 8月 2008年, 17:32
Is there a reason why you can't use the NURBS model? If I would be doing a high rez car render, I would rather have a NURBS model instead of polygon. You can simplify the NURBS model as well. Convert the NURBS to polygon will be one of the reasons that it will choke the machine...
文章cottonsan072 » 13日 8月 2008年, 20:43
I don't understand why either! Somehow, this has been the procedure of this Japanese car company to ask vendor to handle OEM CAD data. I guess I'll know in few weeks!
cottonsan072
文章: 103
來自: NEW YORK, USA
文章Siegfried » 3日 4月 2009年, 10:56
I don't know which software you used to render finally, but for instance, Flamingo, will calculate and render the NURBS in form of Meshes.
文章Siegfried » 3日 4月 2009年, 10:58
文章HapZungLam » 6日 9月 2009年, 08:24
I had the same problems before. I used "polygon reduction" in XSI, it works great
回到 ■ Modeling
