Maya bevel plus一問~~~
有關 Modeling 技巧討論
文章mayanoob » 16日 5月 2006年, 03:42
我想用bevel plus黎做個車"令"。首先我create左curves。跟住選最外圍的curve,跟住選入面的。
然後用bevel plus。但系唔知做咩系error。佢話我無選出面條curve,又話有history。。。都唔知做乜。
麻煩甘多位高人教路~~
here is what the scrip said
select -r curve15 ;
select -tgl curve16 curve17 curve18 curve19 curve20 curve21 curve22 curve23 curve24 curve25 curve26 curve27 curve28 ;
bevelPlus -constructionHistory true -normalsOutwards true -range false -polygon 1 -tolerance 0.01 -numberOfSides 4 -js true -width 0.1 -depth 0.1 -extrudeDepth 0.4 -capSides 4 -outerStyle 2 -innerStyle 5 -polyOutMethod 2 -polyOutCount 200 -polyOutExtrusionType 3 -polyOutExtrusionSamples 2 -polyOutCurveType 3 -polyOutCurveSamples 12 -polyOutUseChordHeightRatio 0 "curve15" "curve16" "curve17" "curve18" "curve19" "curve20" "curve21" "curve22" "curve23" "curve24" "curve25" "curve26" "curve27" "curve28";
// Error: bevelPlus2 (Bevel Plus Node): The first curve must be outside other curves //
// Warning: You have an empty result since history is on. You may want to undo the last command. //
// Result: bevelPolygon2 bevelPlus2 //
// Error: bevelPlus failed - open script editor for details //
i already seleted the outer curve first...... :(
mayanoob
文章: 31
註冊時間: 13日 4月 2006年, 11:36
文章stantang » 16日 5月 2006年, 10:05
can you upload a screenshot or the file here? it's hard for us to help unless we can see what's happening.
文章mayanoob » 16日 5月 2006年, 22:33
oo, i restart maya, then it works suddenly....weird....
but thanks anyway~~ :D
mayanoob
文章: 31
回到 ■ Modeling
