rigging problems~ help! help~~!!
有關 Modeling 技巧討論
文章mayanoob » 15日 11月 2006年, 12:32
i put the model into a controlar already.
and the joints are in it's own group.
then after i do smooth blind to the model.
i try rotate the model and joints with the controler.
but
the joints not rotating with the model together.
can someone help help~ please please please
i use maya 6.5
mayanoob
文章: 31
註冊時間: 13日 4月 2006年, 11:36
文章stantang » 15日 11月 2006年, 14:41
No so sure what you're asking... sounds like another "double transform" problem...
If your model has been binded already, then you shouldn't rotate it directly. Instead, you should rotate the root of your rig in order to rotate the model.
文章mayanoob » 15日 11月 2006年, 15:40
i mean when i try to rotate the contoller. ( the model is inside the controler). the model moves, but the rig doesn't follow.
mayanoob
文章: 31
文章CraZ3D » 15日 11月 2006年, 17:18
Cap screen 黎睇睇 ~~ 8)
CraZ3D
文章: 1068
註冊時間: 12日 8月 2001年, 08:00
來自: Hong KONG
外號: 富X代
Re: rigging problems~ help! help~~!!
文章stantang » 15日 11月 2006年, 17:41
I think I sort of getting what you means...
Do you mean your model is under a "controller" node and your joints are in another?
Example:
- controller --> model
- XXX node --> joints
If that's the case, the joints won't move with the model if you rotate the "controller". You should have your joints under the controller instead then take the model out of the "controller" group.
This is because the controller will transfer the rotation to the joints then the joints will transfer the same rotation to the model since the model is binded (controlled) by the joints.
文章mayanoob » 15日 11月 2006年, 17:51
ooo~ thank you so much stantang~
this is what i want la~
thank you so much~ :lol:
mayanoob
文章: 31
回到 ■ Modeling
正在瀏覽這個版面的使用者:沒有註冊會員 和 21 位訪客
