[Sobig 注意] Hi question about motion capture .fbx to 3Ds Max Biped
有關 不同種類的Animation 技巧討論
版主: 陳根
文章deshk » 31日 5月 2010年, 14:08
hi, would like to ask a general question about the process of applying.fbx motion to 3Ds Max Biped.
Thanks,
Des
deshk
文章: 46
註冊時間: 13日 12月 2006年, 19:31
Re: Hi question about motion capture .fbx to 3Ds Max Biped
文章陳根 » 5日 6月 2010年, 09:36
deshk 寫:hi, would like to ask a general question about the process of applying.fbx motion to 3Ds Max Biped.
Thanks,
Des
抱歉 deshk,雖然你post 響animation forum,但小弟並非max 人,所以答你唔倒。Sobig 兄,你應該幫倒呢仁兄/姐架呵。 :wink:
陳根
文章: 2016
註冊時間: 25日 11月 2002年, 20:37
來自: 五湖四海
外號: 根製作
文章sobig » 7日 6月 2010年, 17:01
users can only import BIP, BVH and CSM to biped.
you should not able to import FBX to biped.
if you are talking about FBX between Maya 3dsmax, you can try it in MotionBuilder.
you can import FBX to MotionBuilder. then, MB will output a better skeleton to Max. i am not sure whether MB can output biped.
hope this help
文章mUser » 7日 6月 2010年, 17:36
Motion builder can export BVH , then import BVH to Biped in MAX
mUser
文章: 206
註冊時間: 25日 6月 2006年, 01:29
文章deshk » 8日 6月 2010年, 01:08
Thanks all of u,
yea I manage to get both of the bip and fbx.
And they were exported from the motion capture.
However, the finger motion isn't applied to the fingers.
How can I fix the problem?
mb is maya default file format .mb right ?
deshk
文章: 46
回到 ■ Animation
