小弟用maya8.
好多時貼左圖
關了maya後
下次再開返想約繼做時
之前貼的圖,全部都話link不多
點樣可以不用再由頭link過呢
版主: h2o
stantang 寫:Seems like you're using some absolute path instead a relative path. and you have one more "" before "sourcimages" in the path name. Try change your path to something like "sourceimages\XXX.jpg" instead. If you set your project right, the texture should load up without problem.
The other thing that might cause problem but I'm not sure is the chinese word in your link. May be Maya doesn't like that... I don't know since I never used Maya in Chinese windows. May be h20 can answer.
正在瀏覽這個版面的使用者:沒有註冊會員 和 20 位訪客
