Features >>
Native Operators: Ocean, Ripple, Wake, Swell, Curved Wake, Air.
Custom toolbar providing direct access to the operators.
Per-operator adjustable precision settings.
Main simulating parameters (i.e. wind velocity, wave height, etc.) driven by the icon SRT transformation.
On the fly adjustable preview grid resolution.
Fast switching between preview and infinite ocean.
Automatic render tree setup: each time an operator is applied to the ocean surface, the corresponding shading node is added to the render tree.
Photo-real wave shading capability with mental ray 3.0 using advanced bump/displacement shader combination.
By hand adjustable render tree: each node can be added/removed independently by the plug-in operator. For example, use the Psunami bump/displacement nodes together with a standard XSI illumination shader.
Automatic atmosphere color based on sun direction.
Underwater depth fading.
Haze and rainbows.
Cross-platform floating network licenses.
Fast installation from inside XSI.
Psunami-to-RenderWorld interface allows you to model ocean inside of XSI and render through RenderWorld
詳細資料可參見這裡
http://www.areteis.com/products/xsi/psu ... erview.htm
Docs & Tutorial (PDF)
http://www.phoenixtools.com/private/dow ... TutPDF.zip
