Does anybody know MentalQue?
版主: HapZungLam
文章zcom » 8日 10月 2001年, 11:31
i found a freeware for render which is call MentalQue ?ndoes anybody know how to use that stuff?
zcom
文章: 18
註冊時間: 6日 10月 2001年, 08:00
來自: hk
文章aj » 11日 8月 2002年, 10:26
HI zcom:
You may try this "RENDER Q".
http://arvid.ath.cx/renderq41.zip
一套批次算圖的軟體 主要功能可以連續執行算圖任務 可以在系統背後執行 不需要開啟 xsi主程式 需要較小記憶體 可以在系統背後執行 相當多功能 例如 ZPIC
甚至可以在 render 完後 寄 e-mail 至任一信箱 還可以 loop batch,重復算圖 例如用xsi 主程式算圖會當機 就可以用這功能試試...
Some info from www.edharriss.com...
"SOFTIMAGE XSI Render Farm Tool. Support for passes, RQ will
retrieve them for you from the scene. Sequence segmentation, lets the user split the total sequence into smaller parts, thus preventing memory buildup. (the user defines number of frames per segment and RQ manages the rest, supports negative frames also) E-mail notification, RQ will send an email to any adress when the batch is completed. RQ will play a sound when the batch is completed. -guilic option implemented. Small render client that will launch your render every n:th second, unless one is already running. Also good for looping your batch to get around problems with crashes. Some common render options such as ZPIC, resolution, aliasing, sequences, output filename and path, image format, picture standard and field settings.'
Be 5D。
aj
文章: 43
註冊時間: 9日 8月 2002年, 09:55
來自: Outer Space.
回到 Autodesk Softimage
