由 HapZungLam » 9日 7月 2004年, 23:55
Symmetry map is totally useless unless you want to mirror weights. But, are you sure it doesn't work with negative clone?
you right click on your model and hit clone, scale your model in -1x.
you may merge them with your original to see it with no seam, or you may go modify -> poly mesh -> symetrize polygons. Symetrize polygons is working the same as the addon you've shown.
