今日試過塊 Cintiq
有關使用Wacom 數碼繪圖板的心得及討論
今日試過塊 Cintiq
文章Andrew Lee » 28日 7月 2006年, 23:04
今日喺動漫展試過塊 Cintiq, 感覺有D delay :roll:
文章hollowman » 28日 7月 2006年, 23:22
Hi Andrew
I have a Cintiq
The delay depend on the machine they using,
I use a PC with CPU 2.8GHz with 1G ram
and a macbook Pro
both run cintiq without any delay. very good!
the color range and viewing angle is great too! the viewing angle better than some Ezio LCD mon which over $10000.
but the main problem of cintiq is the reflection on screen, really hard to use in area with window and light .
hollowman
文章: 29
註冊時間: 1日 7月 2004年, 15:44
文章Andrew Lee » 30日 7月 2006年, 02:03
我問過果檔野d人,佢地話要成二萬幾銀呀 :o
文章wkin99 » 30日 7月 2006年, 03:35
我上年尾都試過下,但畫野時怕隊村佢,所以就住就住吾敢用力 :cry:
文章leeho » 30日 7月 2006年, 09:49
:roll: 下次有時間 , 都要去展覽會試下 , 好畫否 :P
文章hollowman » 30日 7月 2006年, 10:24
$20000 cintiq =
21" wacom intous3 +
high quality 21" LCD mon +
dream come true -- draw on screen directly.
and actually speed up production time
cause u can rotate the screen, easier to draw straight line.
and more accurate to draw detail, no need to guess the position.
hollowman
文章: 29
文章wendyman » 19日 8月 2006年, 00:44
Yes, Cintiq can rotate the monitor to suit your drawing pose. If you think HK$20,000 is too high, you can try a cheaper one "P-Active XPC-1700B", it is a 17inch monitor with 1024 pressure level, and just cost you HK$9,800, but it do not support rotation.
I have thought using tablet notebook with wacom technology to do Cintiq job, but most of the tablet only support 128 pressure level(please see the press release from wacom website).
I would like to buy one(Cintiq) in coming computer exhibition, there are some demo machine let you try o draw.
Regards,
Man
wendyman
文章: 118
註冊時間: 5日 3月 2002年, 08:00
文章LAMZA » 19日 8月 2006年, 20:39
動漫展我都有玩過塊 Cintiq,都覺得有少少delay!
LAMZA
文章: 596
註冊時間: 9日 4月 2004年, 21:33
文章supercat7xx » 1日 9月 2006年, 15:56
supercat7xx
文章: 282
註冊時間: 12日 11月 2002年, 12:30
文章wkin99 » 1日 9月 2006年, 16:45
http://www.wacom.com.hk/accessory.htm
裡面有多種型號的筆,吾知有無人用過呢。
另外要多謝亞LeeHo兄,比左幾枝筆咀我,不來咁貴!!
文章Andrew Lee » 2日 9月 2006年, 02:12
wkin99 寫:http://www.wacom.com.hk/accessory.htm
裡面有多種型號的筆,吾知有無人用過呢。
嘩!原來咁多只筆呀,我都想試嚇 :o
回到 WACOM tablet 討論
