Pie-eating
Pie-eating
文章Siegfried » 26日 3月 2003年, 13:48
I wanna make an animation about pie-slicing. At start, the cylinder is full, then after certain time, a sector was gone gradually until nothing is left, what am I suppose to do in Max?
文章marcus » 10日 4月 2003年, 11:08
你要create一個cylinder, 然後系參數果度enable slice option,下面會有from 同to既數值,系slice to既數值方格rightclick,click系最底既show in track view,然後再系裡面設定咁就得咖啦~
希望幫到你啦~ :)
First, create a Cylinder object. Enable the slice option under parameters. Rightclick over the "Slice From" value box and choose show in track view. Finally setup values in the track view and you'll get as follows:
marcus
文章: 54
註冊時間: 14日 6月 2002年, 14:17
文章Siegfried » 10日 4月 2003年, 13:06
Yeap...I solved the problem already, thanks anyway!
[建議]
文章Boaz » 12日 4月 2003年, 00:47
用'布林"逐啖咬.........好似個感覺好d
希望...
希望有一天,能用CG,為我所信的神做點什麼....
Boaz
文章: 175
註冊時間: 19日 2月 2002年, 08:00
