請教~
請教~
文章chat19 » 29日 1月 2007年, 10:31
想請問 each polygon 會有條斜線 display 出黎, how to turn it off ??
also, while i turn on the snap, the snap is too sensitive whts the best setting for the snap?? and some how i dont know why while the snap is on , everything in max getting laggy...
thxs for yr kindly help~
chat19
文章: 23
註冊時間: 2日 8月 2004年, 04:04
文章sobig » 31日 1月 2007年, 10:39
斜線 display >>>
right click on your object, choose Properties>Display Proerties column>Uncheck "Edge Only".
Snap tool>>>
you find the Snaps Toggle button on the top menu. the icon is like a 磁磚.
Snaps setting>>>
Top menu> Customize>Grid and Snap Settings> ........you can adjust everything like display, scale, grids size or sth... :)
