questions about FOV in 3d max
文章ayakiryu » 23日 9月 2011年, 17:18
Hi I saw there is a functions called FOV in the camera mode in 3d max . Wondering is it good for present a character ?
ayakiryu
文章: 138
註冊時間: 17日 1月 2010年, 12:48
Re: questions about FOV in 3d max
文章LoGao » 23日 9月 2011年, 17:50
FOV related to your camera angle (called Lens in max camera).
I don't know how to define"is it good" because you must have the FOV value when you have a camera.
You can't ignore the FOV when you are presenting the character.
文章sobig » 24日 9月 2011年, 13:58
what do you mean FOV function in camera mode?
FOV must be activated automatically when using any kind of camera.
it depends on your setting of FOV if you are talking about the suitability of presentation.
文章LoGao » 26日 9月 2011年, 16:59
um...usually, wide angle lens for presenting full body of the character.
(e.g. 24mm lens, you will get a larger value of FOV)
Tele lens for medium or close up shot.
(e.g. 85mm lens, you will get a smaller value of FOV)
正在瀏覽這個版面的使用者:沒有註冊會員 和 11 位訪客
