Blueprint setup 問題
Blueprint setup 問題
文章gtr333333 » 8日 11月 2008年, 17:49
我試左幾次都發覺個size同個位置都唔巖,請問:
1) 點樣去cut個正確size?
2) 相片顯示既size系用pixel,咁系max入面點樣打個size unit??
唔該~ :oops:
gtr333333
文章: 41
註冊時間: 25日 9月 2008年, 13:22
文章sobig » 8日 11月 2008年, 23:52
do u mean that method?
and the max file for yr ref. Max 8
car_plane.rar
(15.3 KiB) 被下載 562 次
文章gtr333333 » 9日 11月 2008年, 02:17
sobig 寫:and the max file for yr ref. Max 8
唔該哂你先,其實點set個blueprint我都知道基本點樣做,而家我問題系cut好哂front, back, top, side之後出到黎開始畫發覺唔對位,所以想問下點樣去cut張blueprint先巖? 重有就系個units問題,例如張圖200x200pixel, 咁我系max入面點set個巖size既plane呢?
唔該哂~ :oops:
gtr333333
文章: 41
文章sobig » 9日 11月 2008年, 12:02
pls open my max file.
then, you will figure out what i mean.
for setting a correct proportion of reference image, we can do it by several planes + UVW mapping.
you can just move and scale the specific scale of your reference there.
however, it is important to click "Bitmap Fit" under the UVW mapping.
it ensures you get the correct proportion when scaling your ref image.
Or, you can crop those images in photoshop 1st.
then you can just import those images instantly in max.
if you really want set the units, you can......
go to Top menu>Customize>Units Setup.
you can set up your own units.
hope this help
文章gtr333333 » 10日 11月 2008年, 13:00
問題已解決,真系唔該哂你! :P
gtr333333
文章: 41
文章sobig » 10日 11月 2008年, 13:14
