I need some tutorial about max
文章marino » 3日 8月 2002年, 13:34
hi everyone.... I start to learn 3d max now, can anyone post some tutorial exercise about max for me....thank you thank you....
Actually I 'm a lightwave user . Does the company in hk runnig lightwave? it seems to be all the company using max instead of lightwave...so I have no choice to learn 3d max.
marino
文章: 92
註冊時間: 28日 3月 2002年, 08:00
Field
文章Siegfried » 3日 8月 2002年, 19:33
In which field U're suppose to join, animation, int-design, graphics or product? They may be different from each other enomously!
文章marino » 3日 8月 2002年, 22:12
^_^
I need somthing about animation and modelling ...because I wanna to make a animation which composite with the live video..
are there have any tutorial about composition of live video..?
marino
文章: 92
Great
文章Siegfried » 4日 8月 2002年, 13:48
You can try After Effect for compositing, and Max for animation or modelling was not a bad choice, of course not the best.
文章xam » 30日 8月 2002年, 13:20
3ds max and Combustion will be a partner, as Combustion (from discreet also) can support max RPF file and the functions (e.g. keyer, mask, LUT) are more professional and high-ended.
And one cannot say that which animation software is the best. When one software seems so good at the moment, another software will come with a newer version that seems again to rule the world. All an animator need to do is to train up his animation skills (not the software skills (it's relatively easy)). That's what make the difference.
If you've seen the animations created by Blizzard, you will know what I mean. I met them in Siggraph 2002 and ask them why they still use max when the whole world seems to go to Maya, and they gave me the answer similar to the above mentioned. And, they said that actually, it's just an illusion of that, especially in HK (you know the sheep effect 羊群心理).
Hope this help!
