新手問題2
新手問題2
文章wanchun » 2日 5月 2009年, 21:55
我對以上既圖有問題~
佢果到系咪有個"標准材質"指住一張圖同一張bump map既~~
佢意思即系咪叫我 map張圖 同埋bump左張bump map?
但系o系英文版 "標准材質"系咩?bitmap?就咁bitmap可以bump埋既咩-.-?
仲有~點解map左落去好似loop住左咁-.-
點搞好?之前都成日遇到哩個問題~定系張圖唔夠高解像就冇得用?系咪4面既連接位一樣既圖先用得?[/img][/url]
wanchun
文章: 21
註冊時間: 18日 9月 2007年, 22:55
文章wanchun » 9日 5月 2009年, 22:58
有人答我嗎?
唔該~
wanchun
文章: 21
文章qoola » 11日 5月 2009年, 09:20
佢圖果粒系 blend shader
將兩粒 shader 混合為一粒 shader ..
承接各類 3D 繪圖工作 (卡通 , 室內 , 產品)
http://www.chchc.com
http://blog.chchc.com
http://ccchan.cgsociety.org
qoola
文章: 83
註冊時間: 27日 7月 2004年, 22:32
來自: 天神村
文章sobig » 12日 5月 2009年, 13:34
sorry to be late, mate.
just extremely busy these days.
here it is.................
there are 2 major methods when you are working with blend/ mix materials in 3dsmax.
i would suggest you are going to use Mix material.
it will be easier for you
Step:
1. select a default material in material editor.
2. click "diffuse", choose "Mix".
3. there are 2 bitmaps + 1 mask bitmap you can input under "Mix" material.
4. browse your 2 bitmaps you want to mix.
5. browse a B&W mask bitmap that will help you to mix your bitmaps with relating pattern.
6. after that, you should see a Mixed material
P.S. if you find your pattern is too repeated/titled, you can draw a a bigger mask image.
then you can use it with another Unwarp UV mapping.
i expect you apply UVW mapping to those 2 bitmaps.
hope this help
文章wanchun » 13日 5月 2009年, 23:30
唔緊要~~
唔該曬~~
wanchun
文章: 21
