Vray can achieve this kind of effect ?
版主: xam, sobig
文章sobig » 18日 9月 2009年, 00:05
material editor>>> no way to fix it. you can just delete some of material balls. then you can have an new one to use.
64bits max>>> it will be faster when u are doing some heavy rendering and simunlation. otherwise, you will have an normal speed when running some simple scenes.
a small part of image>>> go to Top menu>Rendering>Rendered Frame Window.....select "Region" under Area to Render
文章aniOcean1204 » 13日 10月 2009年, 00:37
thanks a lot, sobig. :)
aniOcean1204
文章: 11
註冊時間: 14日 6月 2007年, 20:17
上一頁
