為何 Max 5 的 "Lightscape 型 Radiocity Render 會饅過 Fi
文章yanyu » 20日 8月 2002年, 21:34
:o 為何 Max 5 的 "Lightscape 型 Radiocity Render 會饅過 FinalRender ?
cause in standard said, FinalRender is a plugins,speed is slow than Max original render, but why now i using my PC to test Rendering, FR can run faster than the Max5 Original Radiocity Rendering. The FR is Highspeed n the Quality is best....
But the Max5 Radiocity render is too slow, quality is "OK lah...."
i dont know where is the discreet something wrong? is it the Max using Lightscape style rendering keep slow the render time?
my PC is Dual P3 1Ghz, 1G Ram, Using WinNT5(2000 SP2)
All kindness pls reply my using Chinese.
Thanks.
Make my crazy dream on a CLICK.
yanyu
文章: 7
註冊時間: 4日 8月 2002年, 16:38
來自: Malaysia
文章xam » 30日 8月 2002年, 12:30
It is very difficult to compare two totally different render engines because they have different algorithms. Final render is a "view dependent" GI engine and Radiosity is a "view independent" engine (it is not counted as GI as far as I know, it is radiosity). You can also choose "Light Tracer" in max5 to render, just add a skylight under create panel>light, then render it with light tracer GI engine to see.
Hope this will help..... ^_^
