唔用filet整圓條線仲有咩方法??
唔用filet整圓條線仲有咩方法??
文章ayi » 26日 11月 2002年, 23:15
我想問..我要弄一個萬字夾
咁萬字夾兩端咪圓圓地咁...
但唔可以增加segment情況下
(因為用filet會將vertex一開2的)
又要弄得好似filet咁圓的靚... 請問點好??
ayi
註冊時間: 26日 11月 2002年, 23:03
文章workwire » 27日 11月 2002年, 00:46
draw a box use editable Mesh and extrude the mesh on the face... edit them like LOW poly Mesh .......... play with the MOVE tool then apply the Meshsmooth to get fine model .... :wink:
workwire
文章: 36
註冊時間: 6日 9月 2002年, 12:53
文章xam » 20日 12月 2002年, 17:24
Just draw the a paper clip shape using lines (and arc maybe), then check the Renderable checkbox under the Rendering rollout of the shape under modifier panel.....
If you don't like this method, you can also draw a cross-section of the paper clip and make use of the shape created before as the path and use Loft object to make the 3d model.
Hope these can help....
