FinalRender
FinalRender
文章zcc411 » 7日 12月 2002年, 01:56
各位,
請問 FinalRender 其實是什麼, 作用是在那裡呢??
而且有分不同的stage, 那又是什麼呢??
zcc411
zcc411
文章: 9
註冊時間: 19日 8月 2002年, 23:26
Final Render
文章Siegfried » 7日 12月 2002年, 21:42
Final Render(FR) is a plug-in renderer for Max, just like Mental Ray, which also create radiosity and caustic effect, but the benefit of FR id speed, the reality is more than acceptable, when you compare with Mental Ray, but I think I'll stick to it when it comes to HDRI.
how to install final render fully?
文章yetsing » 8日 2月 2003年, 15:54
I use 3ds max5.
People told me I should install final render 1.5 for max5.
After installation, there are just FR light.
And other people told me that I should install final render stage-0 + final render 1.4 for max + final render 1.5 for max5.
how can I do?
yetsing
文章: 27
註冊時間: 9日 1月 2003年, 21:19
來自: Shanghai, China
Sorry
文章Siegfried » 8日 2月 2003年, 17:13
I'm still using Max 4.2 + final render, so I'm not able to answer your question, but I've tried the default GI of Max 5 and it works pretty good-or acceptable(not that accurate if you're picky).
But I don't know the latest version of FR compatible to Max5, is it FR 1.5?If so, use it but beware of the bugs. :wink:
