[問題]新手問題
[問題]新手問題
文章Cyruslam » 16日 3月 2003年, 19:18
請問下邊道有教用edit patch架,因為唔系咁明patch點用!
Cyruslam
文章: 15
註冊時間: 19日 12月 2002年, 22:05
文章Siegfried » 17日 3月 2003年, 09:15
See the tutorial in the Max, there are also some Korean books specially about patch modelling (organic model), they were translated to Chinese.
文章Cyruslam » 19日 3月 2003年, 11:38
借問聲系邊道有呢o的書買?
thanks
Cyruslam
文章: 15
文章Siegfried » 19日 3月 2003年, 11:44
I bought it in Wan Chai, under HK$100.
Or if you have any problem, post your question here, we'll give it a try. :P
Cool
文章xam » 3日 4月 2003年, 23:25
Tsuen Wan "Tsuen Fung Centre"
Sham Shiu Po "Golden"
Mongkok "Star" and "Mongkok Comp. Ctr."
WanChai as Sieg' said.
Yes, pls take a look in max "tutorial" under help menu. R u using max 5, the tutorial is quite good this time.
BTW, try using Editable Poly, this is the next generation modeling method :wink:
