Anyone can help me?
文章Iori Keith » 9日 4月 2002年, 16:34
I am the first user for mental ray in 3dsmax. "There are no global illumination generators in the scene" appear when I use global illumination for rendering. What can I do?
Iori Keith
文章: 118
註冊時間: 21日 12月 2001年, 08:00
文章Siegfried » 11日 4月 2002年, 00:25
I encountered the same problem, did you check boxes in the object properties? Did you place the appropriate .dll files in the appropriate Max folders? I don't know where to put so I just paste them all over the places, and the generator works but the scene still doesn't work, anybody help?
I tried FinalRender, it render very fast and good.I don't find any big difference b/w 1 CPU and 2 CPU rendering.
文章Iori Keith » 15日 5月 2002年, 14:54
but when i used final render, always so the dialog box to ask me licence authozation, but i already done.
& when i used final render's lighting, no lighting appear, only effect in active viewport.
Iori Keith
文章: 118
Auth
文章Siegfried » 17日 5月 2002年, 00:49
I remember that you needed to register it twice with different codes with the attached crack .exe file.
Did you check the boxes in the properties dialogue(Right mouse button)? You need to activate the GI for the objects and lights created. Also, please read the instruction file attached in the disc which instruct how to manipulate Final Render, you should make it without problems, but read all of them.
文章Iori Keith » 18日 5月 2002年, 04:17
Thanks Siegfried, I already solve it .
Iori Keith
文章: 118
正在瀏覽這個版面的使用者:沒有註冊會員 和 12 位訪客
