Shadow of opacity mapping
文章schgrass » 22日 10月 2005年, 16:49
I've use opacity mapping and light source to make the following scene. However, there is no effect on the shadow. The shadow still appears as the original shape as the object.
After then, I've exclude the shadows of the object and add a volume light. The result appears a "transperant slide" on the alpha area.
Do anyone know how to solve this problem?
schgrass
文章: 9
註冊時間: 8日 7月 2005年, 00:39
文章khhccotr » 22日 10月 2005年, 23:13
shadow type : shadow map -> raytraced shadow
khhccotr
文章: 4
註冊時間: 28日 9月 2005年, 22:55
文章schgrass » 23日 10月 2005年, 01:08
khhccotr 寫:shadow type : shadow map -> raytraced shadow
Thanks for answering. Must I use "raytraced shadow" instead of "shadow map" or "area shadow" to tackle this problem?
schgrass
文章: 9
文章xam » 25日 10月 2005年, 22:15
or use projector map to project the shadow. But I think use an extra light to create the shadow only will be fine.
正在瀏覽這個版面的使用者:沒有註冊會員 和 8 位訪客
