easy way to change color for rendering
文章CC88 » 1日 5月 2006年, 23:41
Do you know any software or method to change the fabric color or wooden color easily for color rendering (Please see the attachment)? The software must easy to use and short leadtime to do this changes coz the user is non-professional.
CC88
文章: 3
註冊時間: 1日 5月 2006年, 23:34
文章stantang » 1日 5月 2006年, 23:52
If it's a still only, why don't you render the elements in passes then change the color in Photoshop?
文章kiu » 2日 5月 2006年, 00:16
add a "color correct" shader over the shader that you want to change color
kiu
文章: 19
註冊時間: 17日 7月 2004年, 14:29
來自: Max
文章h2o » 2日 5月 2006年, 00:28
use a mask to change color in photoshop or post softwares
文章CC88 » 2日 5月 2006年, 22:01
kiu 寫:add a "color correct" shader over the shader that you want to change color
would u pls explain it in details? shader is a software or a function in 3DS Max?
CC88
文章: 3
文章CC88 » 2日 5月 2006年, 22:09
stantang 寫:If it's a still only, why don't you render the elements in passes then change the color in Photoshop?
Coz the user is un-professional person so they don't know how to use Photoshop. "drag and drop" is easy for them to control. do u know any software or program have this function?
CC88
文章: 3
文章h2o » 2日 5月 2006年, 23:22
I remember that I saw a JAVA to do sth like that, it'll change color..... hue really
...... a stupid method, use a flash/html to do the interface and create many different color images, then simply click a button to do the change image function. As same as some fashion or automotive websites :lol:
文章kiu » 2日 5月 2006年, 23:52
color correct is a default shader in Max.
like noise, reflect,checker shader. you can find it in material editor.
kiu
文章: 19
來自: Max
