[求助] Mental Ray 新手問題
文章cgdreamer » 14日 5月 2006年, 12:09
我用3dmax 既 mental ray整左個簡單既test, 但系整極都做唔到木地下及furniture 反射落白牆既效果(即系好似用radiosity d texture 會有 color bleed 咁), 可以點? :oops:
cgdreamer
文章: 6
註冊時間: 29日 8月 2004年, 13:39
文章sobig » 14日 5月 2006年, 13:53
did u use Final Gather for GI?
Final Gather can help the GI better by each material.
u can get better color bleed for each shader.
here is my small potato test. it works, mate.
u can the color bleed btw red box,green box and the wall.
文章cgdreamer » 14日 5月 2006年, 14:15
i have enabled the final gather and the samples is set to 300. is it the problem of texture???? :(
cgdreamer
文章: 6
文章sobig » 14日 5月 2006年, 15:32
to me, the amount of color bleed in your scene is look ok.
if the color bleed is too much, it is not natural.
if want more bleed, you can try add some reflection to the floor.
then, the floor and wall have much more relationship.
