3dsmax教學_創建一艘太空船
3dsmax教學_創建一艘太空船
文章CrazyCG » 2日 8月 2006年, 11:35
[font=Arial]Introduction:[/font]
In this tutorial I will build a complete LEGO model from scratch using 3ds max 8. Originally I made this for the speed modeling contest. Since the purpose of this contest is to model as much as possible within one hour, I didn’t model the underside of the bricks (or the underside of the model). For this tutorial I recreated the model and since there was no time pressure, I used some different techniques.
I will start of with modeling some basic pieces and after that the more complex ones. In the second part of the tutorial I will assemble all the pieces together to create a snowspeeder. The third part will be texturing, lighting and rendering.
[font=Arial]Setting up Max:[/font]
I’ll start by setting the “Grid Spacing” to 4.0.
This will make modeling a lot easier since the dimensions (except height) of the LEGO bricks are all a multiple of 4mm.
[font=Arial]The first brick:[/font]
[font=Arial]Set the 2.5D Snap mode and create a box with the following dimensions:[/font]
[font="Arial,]Convert the box to an editable polygon and select all the top edges and side edges. Click on the small button next to Chamfer and enter 0.1 as the chamfer amount.[/font]
Create a cylinder with the following parameters.
CrazyCG
文章: 12
註冊時間: 28日 6月 2006年, 09:52
Convert it to an editable poly select the top edge and chamfer with a value of 0.1 units.
[font="Arial,]
[/font]
Move it up 9.6 (to do this right click on “Select and Move”and enter 9.6 as an offset value for Z).
Turn on the “Snap to Pivot” toggle and from the top view move the cylinder to the center of the box
[font="Arial,]
[/font]
Now you should have the following object:
[font=Arial]More bricks:[/font]
Create another box with the following parameters: L=8, W=16, H=9.6. Convert it to an editable poly, select the top and side edges and then chamfer with a value of 0.1 to get the following:
CrazyCG
文章: 12
文章CrazyCG » 2日 8月 2006年, 11:36
By using a height of 3.2 units, I modeled the plates in the same way:
[font="Arial,]
[/font]
[font="Arial,][/font]
For some other plates (blue) I used the line tool and extrude modifier:
[font=Arial]More complex bricks:[/font]
[font=Arial]For these bricks I started out with a copy of the 16x8x9.6 brick. I used connect to split the side in 3 equal parts and then used connect, extrude and chamfer.[/font]
For this brick I just used inset and extrude to create a hole in the stud.
Here are some more bricks and how they were created:
CrazyCG
文章: 12
文章CrazyCG » 2日 8月 2006年, 15:43
更多教程見:
www.crazycg.org
CrazyCG
文章: 12
