山泥傾瀉
山泥傾瀉
文章ven » 24日 8月 2007年, 10:33
各位brother,有冇人知有咩方法可以做到山泥傾瀉既effect,或者有冇D教學可以參考下????。。。。。。急
ven
文章: 3
註冊時間: 24日 3月 2007年, 21:17
文章sobig » 26日 8月 2007年, 02:13
you can try reactor in max for your case.
it should be heavy for your sence if you are doing 山泥傾瀉.
you build lots of various stones and rocks.
those elements will fall off belong to your cg hill.
it is easy to create that effect by simple collision setting in reactor.
try to get some fun in max tutorial.
