32bit rend圖仲快過64bit?
文章CTW » 17日 9月 2007年, 23:46
我的電腦是Q6600 cpu,2GB Ram,我裝了兩個window,一個XP 32bit,一個XP 64bit,兩個window都試過rend同一個圖,32bit系7:32,而64bit系8:07,點解32bit快過64bit呢?我試過用Vray的Distributed rending,兩部機都是用32bit XP就無問題,如果一部用64bit XP,一部用32bit XP就不能,主機認不到另一部機的cpu,請問是否一定要用相同的window才能造到呢?
CTW
文章: 48
註冊時間: 4日 5月 2006年, 18:45
文章h2o » 18日 9月 2007年, 11:09
Maya+mental ray 完全冇問題, 而且系 64bit 快過 32bit 少少..... 呢d 好睇寫 programme 既 core, 有可能系未完全 optimize for 64bit
文章sobig » 18日 9月 2007年, 13:55
i get a friend whom tried to render a sence with 32 and 64 individually. he found that those are similar speed if the sence is not very heavy. it may get a huge different of rendering speed when working with a heavy sence in max.
and you try to use 32bits as a manager. then, the 64bits should be fine to connect that 32bits. certainly, using same 32/64bits pcs are the best choice. i assume you are using backburner.
