用Direct 3D開OpenGL做的file會有問題?
文章CTW » 21日 9月 2007年, 23:08
我的max行Direct 3D,打開用OpenGL造的file時,如果用smooth+highlights顯示時,max就即刻close,如果用wireframe就無問題,rend圖都無事,用OpenGL做的file是否要用番OpenGL來打開,用Direct 3D做就要用Direct 3D來打開?
CTW
文章: 48
註冊時間: 4日 5月 2006年, 18:45
文章stantang » 21日 9月 2007年, 23:48
a max file is a max file, should have nothing to do what mode you're in when create the file. I think your graphic cars is the problem, should check if it supports Direct3D well, could be a driver problem as well.
文章sobig » 23日 9月 2007年, 01:54
you can test the speed with various dirivers by hand.
different videos have different performances.
