Scale limitation?
版主: xam, sobig
Scale limitation?
文章Kraretto » 23日 9月 2007年, 10:16
Does 3DS Max contain scale limitation? I try to make some models in same scene, from a body to some buildings. And found 2km buildings cannot be moved in a scene. I have already set the UI to be "km".
On the other hand, if I set it as "mm" in UI. I found I cannot zoom in very detail to a small object in Perspective view. It shows broken thing with a distance.
Is my PC problem? or?
Kraretto
文章: 19
註冊時間: 1日 1月 2007年, 12:15
文章sobig » 24日 9月 2007年, 12:33
yes...i guess other softwares also have this problem.
one thing u can do is to set up your whole sence within the "Grid".
in the perspective view, you can see a square Grid in the viewport.
normally, we will not set up a model that is larger than this Grid.
then, your model's scale should be fine.
正在瀏覽這個版面的使用者:沒有註冊會員 和 8 位訪客
