Character Studio Mixer 一問
文章sheep630 » 29日 10月 2007年, 16:35
Don't know why the biped turned to a wrong direction after I combined them in a mixer.
I've got 2 bipe:
1. walk
2. attack
Single import of the bipe has no problem with the direction.
However, problem occur when I import another bipe to the transition layer.
How could I fix it ?? Can anyone help plz~~~~~
Picture attached
sheep630
文章: 97
註冊時間: 27日 3月 2004年, 23:05
cs mixer
文章riccardo1978 » 29日 10月 2007年, 17:37
the transition between the 2 animation seems to be reversed mate. just switch the square brackets around and that should improve the situation.
riccardo1978
文章: 33
註冊時間: 25日 11月 2005年, 12:52
Re: cs mixer
文章sheep630 » 29日 10月 2007年, 18:19
riccardo1978 寫:the transition between the 2 animation seems to be reversed mate. just switch the square brackets around and that should improve the situation.
I checked with the mixer tutorial file and the brackets are in the same way as mine. So, the bracket might not be the problem.
Could you suggest any other idea??
thank you very much
sheep630
文章: 97
文章sheep630 » 29日 10月 2007年, 19:30
i found out all my horizontal movement of the pelvis did in the bipe tends to move in wrong direction in the Mixer.
Where is the problem ??
Is it matter to select an appropiate viewport before saving the bipe?
There must be something wrong in the horizontal movemet, but i couldn't find out.
can anyone give me a hand~~~~~
Problem Files attached
problemFiles.rar
(106.14 KiB) 被下載 543 次
sheep630
文章: 97
cs mixer problem
文章riccardo1978 » 29日 10月 2007年, 21:57
I m pretty sure that it's the transition problem, because the shading of the transition itself shows that it is wrong. did u try to switch the brackets around at all?
riccardo1978
文章: 33
Re: cs mixer problem
文章sheep630 » 29日 10月 2007年, 22:22
riccardo1978 寫:I m pretty sure that it's the transition problem, because the shading of the transition itself shows that it is wrong. did u try to switch the brackets around at all?
Yes, I did try.
However, i can't switch them into opposite direction, once i did that the overlapping bar just gone.
And I aslo create some animated bipe for testing.
I realized that everything bipe I animated rotated 90 degree along the X axis after I brought to the mixer. As I said before all the horizontal movement is turned into wrong direction.
Can you test the files i attached ? thank you
sheep630
文章: 97
cs mixer problem
文章riccardo1978 » 30日 10月 2007年, 09:58
it seems that it was "test02.bip" that is causing the problem. i suggest u try to load ur bip file into biped as usual and save it out again. If that does not work, try save with the "save MAX objects" and "save list controllers" checkbox OFF. Then load into mixer again.
riccardo1978
文章: 33
文章sobig » 1日 11月 2007年, 12:44
riccardo1978 寫:it seems that it was "test02.bip" that is causing the problem. i suggest u try to load ur bip file into biped as usual and save it out again. If that does not work, try save with the "save MAX objects" and "save list controllers" checkbox OFF. Then load into mixer again.
yes, that should be the major issue
